It is currently Sat Apr 18, 2026 3:58 am
PostPosted: Tue Jul 20, 2021 5:44 am
I just installed 2001 hulls on my old 80's hobie 16 frame...I discovered a lateral movement Castings. The hulls when I'm sailing and it seams the hull posts fit loosely in the old corner castings. I read about using tin cans to shim it or epoxying the Castings to the hull posts...I was thinking about using spray foam? Or would the spray foam collapse?
PostPosted: Tue Jul 20, 2021 8:23 am
Foam would not be strong enough. There is a huge lever load up in the castings. Epoxy is a good choice or Brass/Aluminum shims.
