It is currently Tue Jun 16, 2026 7:42 pm
PostPosted: Sat Mar 22, 2008 8:06 am
I'm putting together an '82 H16 with piece parts from three different boats. I have three sets of rudders. One set is a hard plastic or fiberglass material which is fairly light. Set two is also a hard material that seems to be somewhat heavier in weight than the first set. The third set is heavy and dense and has more of a rubbery plastic or vinyl composition. Can anyone tell me which is what and/or which one I should put on the boat?
PostPosted: Sat Mar 22, 2008 3:33 pm
What colors are they?
If the first set is black - EPO Rudders. They're the best. Use them
Second set - white or black - probably racer rudders. Good, but not as good as EPO's.
Third set - White or used to be white (yellowed) - probably Lexan. Put 'em on eBay and some yokel will pay $50 a blade for them.
PostPosted: Sun Mar 23, 2008 6:41 am
I had black EPO rudders on my old boat but all three sets I currently have are white although all are old and fairly yellowed. The first set are attached to the later model adjustable tiller arms with the sliding allen screw. I guess it makes sense to just use those rudders since they were (presumably) drilled for those particular castings.
PostPosted: Sun Mar 23, 2008 10:08 am
If they came with the adjustable rudder castings, but aren't EPO's - then they are Lexan. They're OK, but they flex way too much.
Avoid the ABS rudders. They have a nasty tendency to break off right below the rudder castings.
