It is currently Wed Apr 22, 2026 2:35 pm
 Post subject: Repair Questions
PostPosted: Mon Aug 18, 2008 3:49 pm
I just bought a 1974 H14, its in pretty good shape apart from a few things. I was wondering if anyone could provide some advice on the following repairs:
1. Cigarette-burn sized hole in the main sail, about 1' above the boom near where the blocks connect. Can I buy mylar patches somewhere? I know someone who is really good at sewing so thats not an issue. Would "emergency" sail tape work as a permanent solution? Does a patch have to be mylar or can it be a different material?
2. Missing the two bottom battens (5 batten main sail). What lengths should I have these made to? I know a place that will make custom battens and I dont want to get to my cottage (2 hours away from nearest city) and have two battens that are too short.
3. Pea-sized gouge on outside of port hull just forward of front pylon, it is below the waterline. I think there was a screw sticking up on the piece of crap trailer it was delivered to me on, and left a nice scratch when I launched. The scratch is long and snow-white against the stained hull (I think this is just a scratch in the gelcoat). The gouge at the end of the scratch looks like it goes down to the fiberglass. You can see grey material in the deepest part of the gouge. Can I repair this with aquamend expoxy putty, and sand it nicely? Is it ok to apply it OUT of the water? It says it can be applied underwater so i am wondering if it is ideal to apply it wet.. Can I overlap the putty onto the gelcoat, or can it only be where there is exposed (I think) fiberglass?
4. Boat was left in water and has reddish-brown-orangy stains on both hulls where it was below the water. I tried power washing and scrubbing but the stains didnt budge. Can someone recommend a good product? Is CLR too harsh on the hulls? Will this whink stuff work? http://www.whink.com/rust_and_iron_stain_remover.htm
Thanks in advance for any advice! Sorry for the long post.
Cdogg
cron
