It is currently Wed Apr 22, 2026 8:48 am
 Post subject: Sailtube length?
PostPosted: Sun May 31, 2015 12:07 pm
Cross posting on the Getaway forum: I've arranged to buy a piece of 12" wide pipe that is 20' long. We need to cut it to get it home on our truck and am trying to figure out how long to make each cut. The shorter we cut each piece the easier it will be to get it home (30 miles or so on a mix of freeway and bumpy roads). We have a Getaway and a H (converted turbo) 14 so we could use some for each. Our boats are both in storage in different parts of the city and I probably won't get the chance to go measure anything. I have the battens for the HG mainsail and it looks like the longest one is less than 8'. I'm wondering if it is worth cutting two smaller than 10' tubes and using the extra one for ...?? rudders ?? extra other stuff?
Does anyone know what the minimum lengths I can cut are that are still practical for use?
Thank you for your help!
 Post subject: Re: Sailtube length?
PostPosted: Sun May 31, 2015 2:41 pm
The H14 boom is more like 8.5 feet in case you ever want to put that in the tube. I'd just make two 10' tubes and use the extra room for mainsheet system, PFDs, or whatever.
Jerome Vaughan
Hobie 16
PostPosted: Sun May 31, 2015 2:42 pm
The standard sailtube length is 10'. That will accommodate any model Hobie's sails and other long bits (except a spinnaker pole). Just cut it in half and you won't be limiting yourself to just the 14 or Getaway.
PostPosted: Sun May 31, 2015 10:31 pm
Thank you!
