It is currently Wed Aug 05, 2026 12:06 am
PostPosted: Wed Aug 23, 2017 9:36 am
Restoring a very old H14. All tiller connections are pretty loose. I've found the Hobi 14 rivet guide on the parts page, but it just lists Hobi part numbers. Is there a cross to trade sizes available? Failing that, I am not sure where to go to buy Hobi part number rivets.
PostPosted: Thu Aug 24, 2017 2:44 am
Try here Dan
https://www.mariner-sails.com/sailing/s ... vet-guide/
Click on the rivets below the guide for Hobie cross reference numbers
Personally I would go up one size and redrill the hole especially of the rivets are loose
Cheers Steve
84 Turbo
PostPosted: Thu Aug 24, 2017 6:08 am
Every rivet on your Hobie is stainless steel material, 3/16" diameter. The only variation is the length. Drill out the old rivets and check the overall material thickness of the two parts being joined. Add a little extra length just in case (I've never found extra rivet length to be a problem except on tiller tubes where the rivets opposite one another can crash if they're too long). I typically buy my rivets from McMaster Carr in boxes of 50 (for a fraction of what Hobie charges).
PostPosted: Fri Aug 25, 2017 10:47 am
Thanks everybody!
This stuff is becoming accomplishable!
