It is currently Tue Jun 16, 2026 11:37 am
 Post subject: Rudder Assembly
PostPosted: Fri Jun 06, 2008 6:35 pm
I recently purchased a 1983 hobie 14 and I have limited experience with hobie cats. The rudders come down easily on both sides, but the starboard rudder hangs up when i try to pull the rudders up using the tiller. When the boat is on the trailer the rudders move up and down when I push and pull on the blades, but hang up when I use the tiller. Are the bolts too tight? Is there a trick I don't know about? Any help is appreciated.
PostPosted: Fri Jun 06, 2008 6:53 pm
Actually just saw the "on the line" article and have linked it below if anyone else has a problem similar to mine
http://www.thebeachcats.com/OnTheWire/h ... ature1.htm
 Post subject: rudder hang up
PostPosted: Wed Jun 25, 2008 7:03 pm
Don't use the tiller. Grasp the connecting rod near the pivot to raise or lower each rudder seperately.
Are your rudders locking down ok? The cams should lock the rudders down when they are latched properly.
