It is currently Tue Jun 16, 2026 5:11 am
PostPosted: Wed Jul 29, 2015 9:40 am
I cribbed this from the Windrider forum.
GUIDE TO ROTOMOLDED POLYTHELENE HULL REPAIR
Boats made of this relatively inexpensive material are incredibly durable and abuse-tolerant as well as near maintenance free.
The intent of this brochure is to provide guidelines for evaluating the repair possibilities and to outline available repair techniques. It is recommended that you honestly evaluate the task at hand and determine if it is within your capabilities or best turned over to a professional.
Damage can result from wear and tear, impact, abrasion, etc. and can be roughly sorted into cosmetic and/or structural in nature, although the line between the two tends to be gray rather than black.
COSMETIC ISSUES & REPAIRS
Cosmetic damage is defined as something that impairs
the boat?s appearance but not its function. On
polyethylene boats cosmetic damage usually takes the
form of abrasion, superficial slits, cuts or gouges, and
localized dents in the hull panels
ABRASION
Abrasion is basically due to wear and tear and if often
localized. Common locations are on the stems or ends of
the boat. Much of polyethylene?s durability comes from its elasticity and
capability to flex and absorb impact and contact. That flexibility is limited under the seat due to the seat structure and the concentration of the paddler?s weight.
Abrasion often takes the form of a series of scrapes and
shallow gouges and in most cases doesn?t need to be
attended to unless over time damage continues to
accumulate to the point where gouges become deeper.
This type of damage will transition from cosmetic to
structural when there is a difference in the flexibility
between the abraded section and neighboring hull
sections. Easiest way to test this is to press on the hull
with your palms and compare the resistance.
If you?d simply like to make your hull look better you can
use a sharp knife (x-Acto? type is good) to cut away any
raised edges along sides of abrasion. A file or Surform?
rasp can also be used effectively to smooth out the hull
surface. Unfortunately, painting is not an option as paint
will not adhere to polyethylene.
SLITS & CUTS
Compared to sharp edged river rocks and ledges and
even coarse grained sand, polyethylene is a soft
material. As such, it will come out second best when the
inevitable collision occurs. Abrasion is one result and a
second consequence can be superficial cuts or slits in the
hull. These are primarily noticeable by the raised edges
on either side of the cut. Again isolated cuts are not a
structural concern. To lessen the cosmetic impact, use a
sharp knife, file, or rasp to remove the raised material. A
rotary tool such as a Dremel? or Black & Decker Wizard
? can also be used effectively to remove the feathered
edges.
GOUGES
Gouges are a tough one. At first, it would seem likely that
a gouge could easily be filled and smoothed but
polyethylene doesn?t provided a good bonding surface for
new material and the inherent flexibility of the material
poses a challenge to the bond between original material
and filler or new material. Other than smoothing the
edges of the gouges as you would with slits and cuts, it?s
best to accept and live with it. If you?d like to try to fill the
gouge, you can follow the instructions for filling cracks
included in section on structural repair.
DENTS
Dents can result from impact from paddling or a weight
left resting on the boat. Long term storage in one position
can also produce hull distortions. Prolonged or continual
exposure to sunlight can distort or stress the hull and
create depressed sections of the hull. Generally, prevention is the best solution to this type of damage. Periodically ease your tie down
ropes or straps. Store your boat suspended in web straps
or resting on rigid sections of hull.
Getting an idea of the source of the dents in the hull can
help prevent future damage but doesn?t help deal with
those already in existence. Just as heat is the source for
some dents and deformation, it can also provide the
solution. Polyethylene has some memory and its? recall
can be encouraged by heat and pressure.
Minor dents can sometimes be removed simply by
leaving the boat exposed to bright sunlight and applying a
gentle pressure on the inside of the hull. If the dent
proves stubborn, you can increase the heat by using a
hair dryer. If still more is needed, a hot air gun may be
suitable but must be used with care. Keep the gun at
least 1? from the hull and in constant motion. Watch
carefully for any signs of glistening or melting of hull
surface. Apply pressure from inside of hull while applying
heat to exterior. Have gloves available to protect your
hands while hull heats.
An alternative approach is to rig a brace to apply
consistent pressure to inside of hull while boat is exposed
to sunlight or heat.
STRUCTURAL REPAIR
Structural damage can affect the hull or such fittings as
deck plates.
A caulk or sealant would seem a likely candidate as a
repair material but unfortunately, polyethylene does not
lend itself to a long-term bond with any sealant. Probably
the caulk that performs best with polyethylene is Lexel ?,
used by many manufacturers to seal the junction
between minicell bulkheads and the interior of the hull.
However, even the best sealant will not adhere well to
polyethylene by itself. Bear in mind that the bond
between bulkhead and hull is reinforced by the
compression of the fitting. The same goes for sealing
cockpit rims or similar applications. Caulk or sealant can
make the junction between fitting and hull drier but only if
used as the filling between the fittings, contained and
compressed by mechanical fasteners such as rivets or
buts and bolts.
CRACKS
The most common structural damage ?poly? boats suffer
are cracks or linear breaks. In many cases, these are
repairable but the process is challenging. You will need
the following tools and materials to attempt a repair of
this type of damage:
- hot air gun with reducing nozzle or propane torch
- wire cutters
- drill (can be done without)
- drill bits (1/8? - 1/4? ? ??)
- file or rasp
- sharp knife
- fine edged metal putty knives (2)
- vise grips (pliers can work)
- coarse grit sandpaper
- polyethylene welding rod (can be obtained from most
manufacturers. Its best to use rod provided by the
manufacturer of the kayak to be repaired.
- denatured alcohol
- gloves
First, thoroughly clean area around crack. Make sure
area is very dry. Use heat gun or torch to dry area but
use them carefully.
Lightly sand area allow each side of the crack, sufficient to raise small fibers on surface of hull.
Wipe down surface with alcohol and allow to dry.
Drill hole at either end of crack with 1/8? drill bit. If drill is
not available, heat end of drill bit with torch, holding bit
with vise grips, and melt hole at each end of crack.
Function of the hole is to prevent the crack from ?walking?
or extending after the repair.
If your ?tool? kit contains a hot air gun:
Insert a putty knife into crack so that a slight gap is
created. If crack is lengthy, insert putty knives as
necessary to open full length of crack.
Position knives so that they are at least 1? from hole at one end of crack.
Preheat the first ?? of the poly weld rod to the point where the rod gets limp and clear as poly liquefies.
Starting ?? beyond one end-hole, apply hot end of weld
rod to the hull. Holding the weld rod at an angle away
from the crack, begin to push the rod onto the crack,
making sure the melted poly fills the end-hole (push rod
into hull and rotate, keeping contact with hull at all times.
Make sure melted poly enters the gap created by the
putty knife/knives. Hold the hot air gun approximately 1-2?
away from hull at a complementary angle to the welding
rod and heat rod and crack as you proceed.
As you approach the putty knife, if possible slide it further
along the crack or withdraw it an angle, always providing
a slight gap to allow melded poly to enter. Make sure to
apply enough poly so that a slight bead is left on the
surface.
Continue applying weld rod to crack, removing the putty
knife(s) as required. Crack should close as you remove
spacers. Make sure that the applied poly from the rod is
still hot and liquid as the crack closes behind the point at
which you are working. At end-hole opposite of where yu
started, melt enough rod to overfill hole (insert rod into
hole and rotate rod. Make sure you keep end of rod in
contact with hull as you push it down into hull and pull it
out. Apply rod to hull approximately ?? beyond hole.
Do not pull the rod away as you finish as this may pull
some of the applied poly with it. Cut unmelted rod with
w ire cutters or crimps.
Smooth out the bead of poly sitting on top of crack, using
gloved hands. Judiciously heat bead with hot air gun and
press and smooth with hands if you want a smoother
surface.
Allow hull to cool completely before moving or disturbing.
Test the quality of bond by pushing corner point of putty
knife under edge of applied polyethylene and prying up. If
bead lifts easily or bead rises down along the crack, you
have not achieved a good quality repair.
ALTERNATIVE METHOD USING A PROPANE TORCH
A torch with open flame is fine for generating heat
necessary to conduct repair but it is not recommended to
melt the weld rod poly directly with a torch. Use a drill bit
as described to melt the rod.
Drill end-holes at end of crack as described above. Insert
putty knives as described to slightly open crack (no more
than 1/16?).
Clamp drill bit in vise grips so that shank or smooth end
of bit extends from jaws of vise grip. Heat end of bit until
it glows red hot.
Apply end of bit to crack in hull and heat the plastic until it
begins to melt. Rolling the bit or working in a circular
motion is effective.
Holding the poly weld rod against hot bit, melt end of rod
and drip onto crack in hull. Alternate heating rod and hull
surface to keep both hot. It will be necessary to
periodically reheat the drill bit to keep it hot enough to do
its? job.
Proceed along the length of the crack, removing putty
knife spacers as required. Slightly overfill the end holes
and make sure the filler poly from the weld rod bonds well
to edges of holes.
Once crack and end-holes have been filled, cut end of
weld rod with wire cutters. Pass the torch quickly over the
repair several times until the repair poly glistens slightly
and then smooth with gloved hands. Do not allow flame
on torch to contact hull and keep torch moving at all
times. Severe hull damage can result from excess
exposure to flame or excess heat.
Allow hull to cool completely before moving. Test quality
of bond as described previously.
SMALL HOLES
Repair of small punctures is similar to filling the end-holes
on cracks. For tiny holes, it may be necessary to slightly
enlarge the hole first to allow the melted poly to enter and
seal the hole. You can enlarge the hole by drilling with
small bit or by heating drill bit and melting hole slightly.
For best results, heat area around the hole and apply the
melted poly from the weld rod to surface while hull is hot.
This allows repair poly to bond with hull material as repair
cures.
Press melted end of poly rod against hole and rotate rod
in hole to spread adequate repair material in place. Cut
off unmelted part of poly rod. Do not try to pull rod away
as this could pull melted poly from hole.
LARGE HOLES
It is possible to weld a patch to your hull but can be a
tricky process. As its necessary to melt your existing hull
surface at point of repair, the possibility of inadvertently
further damaging your hull does exist. If possible,
rehearse the process on a couple of scrap pieces of
polyethylene before attempting on our boat. For best
results, obtain a patch of adequate size from your boat?s
manufacturer.
A hot air gun is preferable to an open flame torch for this
repair.
Cut the patch so that it is slightly oversized compared to
the hole. The patch material can be cut with large wire
cutters, jigsaw, or circular saw. Shape the patch so that it
is rounded to eliminate sharp edges or corners that could
lift if struck by an obstruction.
Heat patch until it becomes slightly pliable. With gloved
hands hold it in place over area to be patched until it
cools and holds a matching contour to that section of hull.
Sand the hull surface to be covered with the patch to
raise a texture and small feathers of material. Wipe clean
with denatured alcohol and let dry. Take weld rod and
melt a bead of polyethylene in a circle around the hole in
hull.
Heat the area to be patched until hull surface softens
slightly, alternately heating underside of patch as well so
that both attain temperature at about the same time.
Make sure that bead surrounding the hole is soft and
melted. While all surfaces are hot, press patch onto hull
and hold in place.
Take weld rod and melt a bed along exterior edge of
patch, melding patch and hull into one piece. Using
gloved finger or flat tipped screwdriver shape bead of
polyethylene from weld rod so that it smoothes transition
from original hull to patch, eliminating sharp edges.
Allow patched area to fully cool before moving or
disturbing.
An alternative to melting a patch and possibility of
damaging the hull It is possible to mechanically attach
a patch to your hull.
Cosmetically, it won?t look as nice but it can make your
boat serviceable again. The process involves riveting a
patch in place.
To perform this repair you will need the following:
- patch
- drill with bit sized appropriately for rivets selected
- sufficient rivets to secure patch, spaced about 1? apart
along circumference of patch. Length of rivets should be
just long enough to secure the patch and hull material.
Longer rivets can create sharp edges on interior of hull
that can pose a danger to you or your gear.
- rivet gun
- tube of Lexel ? or comparable sealant
- duct tape
Obtain a patch approximately 2? larger in all dimensions
than the hole. If possible, cut edge of patch at an angle to
produce a softer edge. You might want shape edge with
rasp or file or grinder to angled edge. For best results,
heat patch to pliable and hold it against hull to conform to
hull shape. If you don?t have a heat gun, you can place
patch in hot water and heat until it becomes pliable.
Once patch is conformed, apply a bead of sealant around
hole. Apply a second bead to patch, approximately ??
inside outer edge. Apply patch to hull and tape in place
with duct tape.
Mark and drill holes for rivets within ?? of edge of patch,
spacing holes no further than 1? apart. Press firmly on the
patch next to hole to be riveted. Insert rivet in gun, place
shank in hole and install.
For best results, if rivet does not snap at first pull, release
trigger and push head of rivet gun firmly against patch
and pull trigger again. The integrity and dryness of this
repair process is entirely dependant the tightest possible
seal between patch and hull. A tight seal will compress
the sealant placed between the patch and hull.
Allow repair to fully cure as indicated by manufacturer?s
instructions on tube of sealant. If you?d like to maximize
the dryness of the seal, melt a bead of polyethylene from
a weld rod along the junction of patch and hull. Shape
with angled straight edge to provide smooth transition
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
