It is currently Thu Feb 05, 2026 10:40 pm
 Post subject: Mast Fork Fix?
PostPosted: Sat Aug 27, 2016 4:40 pm
So it looks like the mast head fork has completely come off my 2014 Getaway during a capsize.
Any ideas how to fix this?
 Post subject: Re: Mast Fork Fix?
PostPosted: Mon Aug 29, 2016 6:50 am
Adding some detail, I've got the parts from the Getaway (see pic attached)Image parts catalog but it seems to imply that I need the sheave, spacer, screw and nut to replace whole hook assembly. I presume the spacer/nut need to go on the inside of the mast...? If so, any ideas how? The mast head assembly is riveted.
PostPosted: Mon Aug 29, 2016 9:36 am
The hook is not shown as it is rarely replaced.
It is the same as a Hobie 16. Requires rivets. May require larger rivets not they have pulled out or a backing plate inside the mast. Holes are 3/16", so if still OK. You can install with:
10680000 HOOK, HALYARD (12 GA)
8011231 RIVET POP 3/16x1/2 PH
and caps (15/64") 8011291 RIVET CAP
PostPosted: Mon Aug 29, 2016 1:52 pm
mmiller, thanks a lot. Much appreciated.
