It is currently Sat Aug 08, 2026 9:01 pm
PostPosted: Tue Apr 17, 2018 9:21 am
I've got a chance to buy a cheap used trailer for our trailerless 2005 Getaway, but the boat is in winter storage up at the cottage a few hours away, so I can't get dimensions. I'm hoping someone in a warmer place than I am right now can respond with some measurements. The trailer is set up for a bigger boat currently, but is roller "adjustable" within a range. The unmovable dimension is the outside distance of the fenders which is 69" Crossbars are 9' apart which I think should be fine.
Inside Distance between Hulls at narrowest point (Hopefully more than 69")
Outside width of Hulls
center to center distance between hulls (for roller placement)
distance from tramp to bottom of hull (for clearing fenders)
Any help you guys could provide would be greatly appreciated.
PostPosted: Tue Apr 17, 2018 6:12 pm
I have a 2012 Getaway
All are approx. +/- 1/2"
Inside Distance between Hulls at narrowest point = 63"
Outside width of Hulls = 94"
center to center distance between hulls (for roller placement) = 78"
distance from tramp (bottom of crossbeam) to bottom of hull = 21-1/2"
PostPosted: Wed Apr 18, 2018 4:14 am
Thanks very much for your help! It looks like this trailer is too big and can't be adjusted down far enough to take the Getaway. :( Too good to be true.
