It is currently Tue Jun 16, 2026 5:11 am
PostPosted: Sun Dec 12, 2021 8:23 pm
My tiller system on 2020 Hobie Getaway (reversed bows) has always been stiff to move. I notice now that the end caps of the tillers, where the pins are screwed in, rotate freely on older getaways but not on mine.
Should these end caps rotate so the tillers can move more freely when connected to the crossbar?
If so how do I free them up.
At the moment the system is so stiff that the pins are being pulled out.
Follow up question... Why is there a screw on one side of the crossbar near the endcap but a fixed rivet on the other side?
Thanks in advance for any expertise or views on this.
Ashus
Mirror, Bosun, Laser, Fireball, Hobie 16, Dart 18, IOR 1 Tonner, 1720, Ozgoose, Hobie Getaway
PostPosted: Wed Dec 15, 2021 10:32 am
Yes, they should rotate.
https://s3-us-west-1.amazonaws.com/media.hobie.com/item_attachments/1957z52.pdf
PostPosted: Sat Dec 18, 2021 5:22 am
mmiller wrote:
Thank you for your swift response and diagrams.
None of them rotate nor did they from the time I received the boat.
Do I need to remove all the end caps and somehow relocate the shims and caps? Or is it a case of buying a new kit? It's odd because this was a brand new boat and I would have thought these parts should have been assembled correctly from the start.
Ashus
PostPosted: Mon Dec 20, 2021 5:24 pm
Your dealer should fix that under warranty.
PostPosted: Mon Dec 20, 2021 5:58 pm
Thank you Matt, will proceed as advised
Ashley
Ashus
PostPosted: Thu Feb 17, 2022 1:10 am
Hi Matt
I've received tiller connection kit 07 roto. Part no 1957.
However there are no Mylar shims as detailed in your PDF.
Are these necessary or have they been phased out? Or maybe the dealer has sent the wrong parts?
Thank you again in advance for your advice on this.
Kind regards
Ashley
Ashus
PostPosted: Sat Feb 19, 2022 3:50 pm
Tillers all fixed.
The new endcaps are freely rotating in the 3 designated places after sanding down to the required diameter.
The mylar shims have been phased out apparently.
Thank you Hobie, Matt and Rayomarine for the advice and quick response.
The steering system works a treat
:D
Ashus
