It is currently Mon Feb 02, 2026 3:29 pm
PostPosted: Mon Dec 19, 2022 4:52 pm
The female threads on the rear transom that the bolt goes into that holds the pintel is stripped. I'm not sure how to repair it. Does anyone have a fix. The bolt goes in but just spins.
PostPosted: Wed Dec 21, 2022 9:45 am
SLS - Hobie Catamaran Production and Sales
Unfortunately there is no repair for the insert. It is one piece and inter connected.
You might try stepping up a screw size?
If that doesn't work you could through bolt, but this would require a port installed in the aft deck to access the inside of the transom.
The Team at Starting Line Sailing
Hobie Sailboats | Zim | Dwyer | West Coast Sailing
PostPosted: Wed Dec 21, 2022 12:50 pm
How about tapping the screw hole to allow a bigger screw. I have done this a few times to great success.
PostPosted: Wed Dec 21, 2022 3:26 pm
I think JB Weld & Loctite have a product that can repair threads, never tried it. I have used helicoils & inserts for different things in the past.
