It is currently Sun Aug 09, 2026 4:49 am
PostPosted: Tue May 27, 2008 6:54 pm
Has anyone else experienced this problem with their hull graphics? Is there a solution to this without replacing the graphics? If not, are replacement graphics available for the 2004 model?
Thanks,
Barry Martin
PostPosted: Wed May 28, 2008 10:25 am
Graphics are available in the current colors.
The graphics can peel off, but usually stick too hard to remove easily.
 Post subject: Graphics
PostPosted: Thu May 29, 2008 7:31 pm
Thanks for the reply Matt. Does anyone know if it's possible to get the graphics to smooth down again?
Thanks,
Barry Martin
PostPosted: Fri May 30, 2008 9:08 am
I would try some contact cement.
PostPosted: Wed Jul 16, 2008 2:26 pm
I would just as soon take my factory decals off. Do the rotomolded hulls require decals with adhesive or will the slide on type used on fiberglass work? If I choose to paint should I look for any special types of paint that would adhere better than others?
Frank, sailing '02 Getaway in Wichita KS. Lake Cheney
(Hobie 17 RIP, storm of '05)
 Post subject: Re: Graphics
PostPosted: Wed Jul 16, 2008 4:44 pm
Thanks,
Barry Martin
Try lightly heating the sticker with a blow drier and sticking it down. I had marginal luck with it.
Sail Revolution
Join us on our new FB Page!
 Post subject: Boat Graphics
PostPosted: Mon Aug 25, 2008 3:34 am
Matt,
You mentioned that current graphics are available. Is the 2004 graphic still currently used? The boats I've seen that are newer have a different scheme for their graphics. If they are available, please provide a part number as I think I want to order a set before they're no longer available.
Thanks,
Barry Martin
