It is currently Wed Aug 05, 2026 2:20 pm
PostPosted: Tue Jun 21, 2016 8:47 am
Hi, my HC21SE (lying in Corsica, france...) needs a new rudder blade.
I have the opportunity getting an HC18 Carbon reinforced one: is it the same shape and size?
i'd keep the original one on the other side, just want to ensure the HC18 one is not shorter, or different in shape ?
same question for the rudder pins: should I select those for HC18?
thanks,
ludo
PostPosted: Tue Jun 21, 2016 9:52 am
The original 21SE rudder blades were larger - a standard H18 blade will bolt to the castings since they're the same as H18 - shouldn't be a problem - rudder pins same as 18 - yes.
Jacques Bernier
http://www.hobie.com/
