It is currently Fri Jul 03, 2026 10:26 pm
PostPosted: Wed Feb 23, 2022 8:01 am
Is there an option for Plug-in Wheels on the Fiesta? Do you have to use two sets on the front MirageDrive wells?
PostPosted: Fri Feb 25, 2022 1:33 am
Until someone directly answers your question, I will pass along my approach for large multipassenger inflatables. I use one of those collapsible handcarts that open up to form an L shape. I lay the cart on its back and put one end of the hull on the extended frame. I pick up the hull's opposite end and it becomes sort of a wheelbarrow. Only need a line looped over the hull and the handle end of the handcart to keep it together; usually I use an always-affixed bow line. On the way home I multitask the handcart to lug in a load of groceries. Diagram:
I ========================== hull
O------- handcart
PostPosted: Fri Feb 25, 2022 9:22 am
Fiesta uses the same drive wells as all inflatables, so that would allow use of the plug-in carts. You would need two to balance the load.
