It is currently Tue Aug 11, 2026 10:50 am
 Post subject: Rudder line leaks !!!
PostPosted: Mon Aug 01, 2016 9:26 am
I just checked my rudder line tube, water has pushed out all small o-ring and plugs.
- How do you "seal" to prevent leak from rudder line leak on AI ?
- Bungee cord I bought from online are not quality. Where do people buy "hobie bungee"?
I need to fix this asap for upcoming trip. Thank you.
Sale: 12Ah/15Ah Lithium Battery
http://www.norcalkayakanglers.com/index ... #msg959037
PostPosted: Mon Aug 01, 2016 9:49 am
Do you anticipate that your rudder line openings will be underwater most of your trip? If they are not, those openings are probably not a serious leak. Serious leaks occur around the front hatch seal on some boats and around the flat (horizontal) hatches if the ring seals are not lubricated properly.
PostPosted: Mon Aug 01, 2016 10:05 am
Yes the tankwell is underwater due to load I put on the back. Rudder line opening is one I need to fix.
I already did the ROID fix for the front hatch.
PostPosted: Mon Aug 01, 2016 10:14 am
Before Hobie started using the rubber o-rings, we use to fill the ends of the rudder lines with silicon adhesive. Move the rudder just a little every couple of minutes till it sets, so it doesn't stick. It won't stop all water from the lines but will stop most of it. I fill it as far up the tube as it will easily go.
You may also want to shift some weight (battery?) forward to more even the trim of your boat.
