It is currently Sat Jun 15, 2024 6:55 pm
 Post subject: Idler pulley issues
PostPosted: Mon Aug 08, 2016 1:48 pm
Both of the idler pulleys that came with my Island failed, were replaced, and now the new ones have failed. The edges of the pulley are missing or bent downward to the outside. They look like the cable went over the edge, bent the edges down, and now the cable slides right off of the pulley.
Two questions;
1. Does anyone make a stainless steel version of this pulley so I can avoid this issue entirely?
2. Assuming this is my issue rather than a design flaw, am I over-tightening or under-tightening the idler cable?
 Post subject: Re: Idler pulley issues
PostPosted: Mon Aug 08, 2016 3:48 pm
Must be a problem with how it or the pulleys are being installed. Can you give up a picture?
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Mon Aug 08, 2016 5:14 pm
There was an issue with the wall thickness of idlers at some point. Maybe replaced with the older version?
