It is currently Tue Feb 10, 2026 6:20 pm
 Post subject: mirage drive setting?
PostPosted: Tue May 14, 2013 4:09 pm
I almost forgot, I am about 6ft average build, what setting should the pedals have. I had them set at 5. there was a slap against the bottom every now and then. There was enough ,wind that I did not experiment
:roll: :roll: :roll:
PostPosted: Tue May 14, 2013 4:10 pm
If they are hitting the hull move them one notch.
PostPosted: Tue May 14, 2013 8:01 pm
I'm 6'0", too, and I have mine set at 5. I only find that I get the hull slap when I take a very long pedal stroke. If I just shorten up a bit, which is actually more comfortable, I don't get any slap. I figure if the fins are hitting the hull, they are likely extended beyond the range where they are most effective, so it's not really doing me any good to take that longer pedal stroke. I found setting 6 to be a little far forward and more difficult to get my feet set quickly.
PostPosted: Sun May 19, 2013 11:50 am
Set on 5 works for me most of the time. 6 ft with a 30 inch inseam. Short legs!
Sandy
Panama City Kayak Fishing Assn
PostPosted: Mon May 20, 2013 11:18 am
I'm 6'3" with 32/34 inseam and I have mine set on 6. I had them on 5 and I got slap also. Give 6 a try....easy enough to change around while out there too.
