It is currently Wed Aug 12, 2026 12:15 pm
PostPosted: Mon Apr 13, 2015 3:35 pm
Looking for ideas. Can you send photos of how you are storing your Pro Angler. I am getting a 14. Thanks
PostPosted: Mon Apr 13, 2015 6:57 pm
Not using a trailer? I saw someone who made a nice cart with a pvc rack. I will see if i can find it
Boom Hobie Pro Angler Setup: https://youtu.be/y0JIx0izt6c
All Fisherman are liars except you and me, but sometimes I wonder about you.
PostPosted: Tue Apr 14, 2015 5:56 am
Anymore ideas would be welcome. Thanks
PostPosted: Tue Apr 14, 2015 9:14 am
Here's how I did my garage storage initially. I ended up buying a second Pro Angler and made a simple base like the one from this old forum posting. I made this rack when I first purchased my 2012 PA. I now store both PAs on the dual jet ski trailer (PVC rails) and the wooden storage racks are no longer used.
SRAces wrote:
Here's how I will be storing my PA. Since I have the luxury of garage space, I decided to just build a rack to hold both the PA and the wife's Revo 11. Since it is taking up floor space in the garage, I decided to use the bottom area to store extra bags of mulch.
The center support is not attached to the 3 inch PVC so it allows the tubes to shift for a perfect fit. I had originally thought about making a storage cart the height of the truck tailgate, so that when I wanted to load/unload the PA from the truck, all I had to do was slide the PA on/off the cart. Then I could just roll the cart up under the Revo 11 or to the truck.
But for now this works fine. Tight lines!
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Wed Apr 15, 2015 11:20 pm
2015 Revolution 13
2015 Outback
2014 ProAngler 14
2012 Sport
Oregon certified Fishing Guide
PostPosted: Fri Apr 17, 2015 6:18 am
Thanks, Please keep them coming.
PostPosted: Fri Apr 17, 2015 6:25 am
How far apart are yall putting those pvc pipes for the pa's?
PostPosted: Tue Apr 21, 2015 10:13 am
I believe mine were about 11.5 to 12 inches apart. I put the PVC on the wood, set the PA on the PVC and then lined everything up. Then I held the "L" brackets up against the PVC and wood to mark the holes to drill. Not too difficult... :D
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Sat Apr 25, 2015 5:48 am
Here is mine. The dimensions are 7' long, 2' wide, and 3' tall ( to fit tailgate of my f250). I used full 10' sticks of 2" sch40 pvc for the rails and attached them with l brackets. I had to put the small sections of 2x4s on the cross rails because with out them the rails would sag and the boat would rest on the 2x4s of the frame. There is about 1/4" of clearance on the stern area of the boat from the cross section. The best way to do it is to build the cart, put the PVC on the get the PA onto it. Then you an measure and line everything up and fasten it down.
The cart is the bomb though it takes me like 25 seconds to get the boat in the back of truck now. With the heat we have been having down hear in Florida my garage is like 100+deg everyday and there is no deformation whatsoever. When I get back from fishing just slide it onto the cart and wash it down, the back in the the garage she goes.
PostPosted: Mon Apr 27, 2015 8:44 am
Thank you looks great. Is that a home made live well?
PostPosted: Mon May 25, 2015 9:19 pm
PostPosted: Mon Jun 01, 2015 11:17 am
Paulyd wrote:
Paulyd... that is a sweet rack (never envisioned writing that to another dude)! I have a 14' kayak now and I'm looking to buy a new 2015 PA14 later this year. I'd like to build a 3-bunk setup like you have this summer. Is that a 2015 PA in your middle compartment? Can you please provide the inside height of that space? I don't have the boat yet and I want to make sure I allow enough room. Eyeballing the pic I'd guess about 34"?
Thanks,
Greg
PostPosted: Tue Sep 08, 2015 8:19 am
Snookmeister, thanks for the build idea. I picked up my PA14 on Friday and built my stand using your specs on Monday. It is very easy to load and unload from my F150. I am going to add some plywood below for additional storage. Here are a few pictures.
PostPosted: Tue Sep 08, 2015 8:51 am
Congrats on the new PA! That's a good looking storage rack. :mrgreen:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Sat Sep 12, 2015 1:04 pm
I just got finished with my storage cart. I kept my Manta Ray 14 on an unused SS kitchen utility table which I had bolted a 2x4 on each end and suspended a pair of 2" PVC just like you guys have been doing for years. When I got the PA14, I put it on the SS rack and the MR14 was relegated to the floor.
I don't have much space in my shed. So, I did a variation on a theme by leaving enough room to store the MR14 underneath the PA. You can make out the old cart in the background and you can probably tell how little space I have to deal with - much better now.
To anchor the pipes, I didn't curve my washers or use through-bolts, I just used #14 3.5" construction screws through a 1.25" washer and left .25" slack for shifting/flexing. Seemed to be the easiest way to me. The height of the top bunk matches the bed of my truck (same with the SS rack).
