It is currently Tue Jun 16, 2026 11:37 am
 Post subject: Comp-tip
PostPosted: Sun Jul 26, 2009 7:13 pm
Hi, all am wondering how to remove comp-tip from a Hobie H14 the mast bent and is it possible to remove the comp-tip from this or not.Anyhelp would be appreciated,Thanks ahead of time.
The Waters always there,just wanting some good wind.
 Post subject: Re: Comp-tip
PostPosted: Mon Jul 27, 2009 12:35 pm
Yes you can. Drill out the old rivets holding the comptip, Tang and aluminum mast head together. Use a heatgun and heat up the aluminum mast just below the comptip and with the aluminum mast anchored to something (or with the help of another), pull the comp tip out. A little wiggling may be needed. At least that is the way I did it for my H17 :wink:
PostPosted: Tue Jul 28, 2009 12:39 am
Wrong spot for this posting but I have a clear anodized uncut H14 mast a couple hours away from TC if you are interested for $200.
