It is currently Tue Jun 16, 2026 1:14 pm
PostPosted: Wed Jun 13, 2007 10:54 am
I just bought a used, mid-80s Hobie 16. The mast has a comp tip, and I have noticed that where the comp-tip attaches to the aluminum part of the mast there is a little bit of flex (i.e. if you push the comp tip up or down it hinges slightly to where it is attached). Is this flex normal? Should I be worried about the comp tip breaking off while sailing or hoisting the sail?
I appreciate any information.
 Post subject: Flex?
PostPosted: Wed Jun 13, 2007 12:02 pm
Flex?
Likely this is not properly glued in place. I suspect that this is the original retrofit tip with a screw set that passes through it? Remove, coat with epoxy inside the alum and outside the tip and re-install. Be sure you can hold in alignment while it cures.
I use automotive bondo. Many use other types of epoxy, but be sure they cure HARD... the stiffness is more important than the holding strength.
PostPosted: Wed Jun 13, 2007 1:43 pm
I made a quick movie of what the "flex" looks like. Could you give me your opinion after looking at the video? Thanks
http://vocker.superfreethought.com/comptip.avi
 Post subject: Glue it
PostPosted: Wed Jun 13, 2007 2:50 pm
Yep... as I guessed. That is a "bolt-in" version of the Comptip... not glued. Just remove and Glue and it will be fine.
PostPosted: Wed Jun 13, 2007 2:56 pm
thank you very much for the diagnosis. I'll grab my bondo and fix it soon.
