It is currently Thu May 09, 2024 11:00 am
PostPosted: Tue Jun 23, 2009 10:37 am
It is a potential problem to use an older drive in a newer Click-n-Go hull.
Problem: The drum shaft in an older drive can rotate within the drive. The levers pinch the shaft and as the drive rocks... This can "ratchet" open the Click-n-Go lever and release the drive.
The newer drives for the Click-n-Go lever system have splines to prevent this rotation.
The shaft is easy to replace. Simply hammer out the old shaft with the new one.
