It is currently Sun Jun 21, 2026 6:06 am
 Post subject: Factory Grease Brand?
PostPosted: Wed Aug 11, 2010 3:51 pm
Matt,
What brand of grease do you use on new Miragedrives? I've noticed it is a greyish-green color and is very fine and tacky. I put a LOT of miles on my Adventures - usually 20-25 miles a night. Great exercise, but hard on drives. I've noticed your grease doesn't wash out and stays good much longer than anything I've tried.
PostPosted: Thu Aug 12, 2010 9:00 pm
coastbum wrote:
Matt,
We no longer need grease here on the Gulf Coast. Our water is naturally oiled which keeps the drives well lubed. :roll:
PostPosted: Fri Aug 13, 2010 10:29 am
My guess is you can use OMC Johnson/Evinrude Triple Guard Grease....its waterproof and made for parts with friction contact.
A 8 ounce tube sell for about $7.00.
I use this grease to lube my outboard motor steering rack assembly, pivot points.....tilt and trim grease fittings.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Aug 16, 2010 2:38 pm
I'm with you Coastbum (and thanks for the tip Dr.SteelheadCatcher),
I'd like to know the name of the product that Hobie uses as I'm due for a Mirage drive treatment. I recently returned from a journey along the north shore of Lake Superior where I logged 200+ miles. I'll be using my spare drive until I've given my #1 drive a good tune up.
GR8 Laker
PostPosted: Fri Sep 10, 2010 9:20 am
roadrunner did a great write up on adjustments and lubrication. It's in our FAQ section:
viewforum.php?f=60
