It is currently Wed Aug 05, 2026 4:14 am
PostPosted: Sun May 13, 2012 8:18 am
Any one know when Hobie went with the V2 mirage drive in the outback and revo?
Currently own: 2012 AI, 2 - 2012 Revo 13's, 2012 Revo 11,
Sold: 2-2011 Oasis, 2010 Outback, 08 Outback, 08 Adventure, 06 Kona
PostPosted: Sun May 13, 2012 9:48 am
I believe it was 2007. I've had kayaks of every year since 2001 and I'm almost 100% positive it was the 2007 models that started shipping with the V2.
Legal Disclaimer: Any information provided should not be construed as legal, financial, medical or spiritual advice and may cause retina bleeding if read incorrectly.
PostPosted: Sun May 13, 2012 1:43 pm
Hobie is apparently referring to the 2009 and newer Drive as V2. This is a misnomer though, as the Mirage Drive has undergone continuous design and materials evolution on different components throughout the years. There have been at least 3 different sprockets, 4 drums, 3 pedal cranks, 2 pedals, 3 pedal adjustment assemblies, 2 idler pulleys, 3 cables, 4 Turbofins, etc. etc. These parts have been added independently on a continuous basis, not necessarily related to model year changes.
The V-2 Drive probably got its designation from the current sprockets, the only parts actually marked "V2" -- first introduced in 2009 to distinguish them from their predecessors. Their distinguishing feature is a brass insert and threaded mast -- a significant improvement.
Just as important, a new generation drum was introduced in 2008. It is stronger, less prone to warpage, uses different cables that are easier to adjust, and imposes less wear on the cable swedges. The current version has a Stainless insert molded in for minimizing wear on the pedal adjustment holes.
Essentially, the 2009 (and newer) Drive is a major improvement to the 2007 Drive, with 2008 as a transition year. There have been several improvements since 2009 however (pedal position bungees, pedal pads, splined drumshafts, Drive alignment pin, and others.
If you're looking to upgrade an older drive, these are the two items you would want to focus on (1. sprockets/masts and 2. drums/cables, each available as kits).
There may not be a single part still in production from the original Mirage Drive. Any of these old Drives are now referred to a "Older Drives" in the parts book. The amazing thing is you can upgrade virtually any Mirage Drive to current standards -- even the oldest ones are not obsolete! 8)
PostPosted: Tue May 15, 2012 1:49 pm
Thanks for the replies, very informative.
How about the click and go design when was that introduced? Im looking at an 09 outback and adventure. any idea when hull issues were reduced? thanks
PostPosted: Tue May 15, 2012 2:04 pm
2009' model year is when we switched to Click & Go locks for the Mirage Drive.
Jacques Bernier
http://www.hobie.com/
