It is currently Thu Jun 18, 2026 7:23 pm
 Post subject: How Comfortable??
PostPosted: Mon Apr 13, 2015 6:41 am
I am 6' 4" tall with a 34" inseam. Will the pedals adjust enough to make for a comfortable leg extension? Will the ride be top heavy with someone of my size (250lbs) ? I am considering a Pro Angler 14. Thanks
 Post subject: Re: How Comfortable??
PostPosted: Mon Apr 13, 2015 8:32 am
You should be fine. I set my drive in the middle of the adjustment range and I'm 6'. With a PA14 your weight shouldn't matter, if you were looking at a Revo, then maybe.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Mon Apr 20, 2015 6:44 pm
I'm not familiar with the seat to Mirage drive ratios on the PA14. I've got a Revolution 16. I'm just shy of 6'3", 240 lbs, and also a 34" inseam. I wound up with the peddles set a position 6 for a "comfortable for me" leg position. At your height, I'd expect the peddles to be in the outer half of the adjustments. From what admittedly little I've seen of the PA's, I wouldn't expect you to have any stability issues with it. The dealer I went through occasionally has demo float days. Maybe you could find something like that in your area.
Best of luck,
Steve R.
PostPosted: Mon Apr 20, 2015 9:40 pm
Your weight is not an issue as the PA-14 is rated for 600 pounds and the excellent seat is rated for 350 pounds.
I am 6' with a 32" inseam and weigh 172 pounds....I have my seat on the "lower position" and my Mirage Drive stroke is set at position #3.
I found that with my old Outback the seat distance was different than the PA, so the stroke setting was at #5.
You should find the PA-14 to be a nice, comfortable ride for a person your size.
Dr.SteelheadCatcher
Warrenton, OR
