It is currently Mon Aug 03, 2026 8:27 pm
PostPosted: Sun Sep 11, 2022 6:45 am
How can I repair this? What part number(s)?
https://photos.google.com/photo/AF1QipNWu3xPv-SwF0IYLNY7OLXILKfuqgWw9r1ObNE
You can see this drive has a history of failure. It first failed 6 months after the 1-year warranty expired.
https://www.hobie.com/forums/viewtopic.php?t=63785
PostPosted: Mon Sep 12, 2022 10:34 am
You may want to correct the photo URL so we can see it.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Tue Sep 13, 2022 4:41 am
It works for me.
Here is another: https://www.youtube.com/shorts/9BUuzp6J1lU
PostPosted: Tue Sep 13, 2022 7:49 am
It works for me.
Weird. I get the following from IOS Safari/Chrome and Windows Edge/Chrome:
404. That’s an error. The requested URL was not found on this server. That’s all we know.
Ouch! Oh my. You will probably need to work with a dealer who does repairs and mmiller to get the parts and/or a repair performed.
Peter
PostPosted: Tue Sep 13, 2022 9:39 am
MD180 (prior to Kick-Up Version) is far less forgiving when grounding fins, masts or the spine itself. You need a new spine. That one is the V1, so you need V2, booms, masts and new fins.
81499 V2 SPINE (with V2 Booms)
72067002 MD180 ST TURBO FIN KIT V2 (includes 2 Masts 2 Fins)
8020030 CLEVIS PIN (need 2)
81503100 RING (need 2)
PostPosted: Tue Sep 13, 2022 4:24 pm
Would a used Mirage Drive GT work in my 2017? Part number 80010501.
I can't afford to lay out $590.16 in new parts to repair this defective drive.
PostPosted: Wed Sep 14, 2022 8:50 am
Any drive will work.
PostPosted: Sat Sep 17, 2022 4:13 pm
Will my 2017 V1 booms not fit into the V2 spine?
PostPosted: Sat Sep 17, 2022 4:17 pm
Yes, you could do that I suppose. Keep these two booms for possible use later. That way you would not need the masts or the fins yet either.
We have not had any V1 parts for a couple of years, so if a mast or fin fails... you would need the V2 parts.
PostPosted: Sun Oct 02, 2022 2:42 pm
Confirmed that, if you are unfortunate enough to own a 2017 Outback, when the MD180 drive explodes, you only need to buy a new spine (V2) and can re-use all other existing parts, including fins, masts and booms.
I got back on the water today and it worked perfectly.
