It is currently Tue Apr 28, 2026 6:55 pm
 Post subject: Mirage Sport repair help
PostPosted: Tue Apr 07, 2026 7:30 pm
Hello I have a Hobie Mirage sport 2010 with a hairline crack in the bottom of the hull...
right under the middle hatch on the bottom of the floor. The crack is not quite all the way through.. no light shining through the crack.
A couple of gallons of Water get into the hull when I pedal slowly over 3-4 hour sessions. I suspect its flexing the crack when I pedal.
Is it best to drill a hole on either side of the crack and plastic weld it with hobie filler rod?
Or best to use a dremel and grind a small trench and fill in the trench with the filler...
Any advice would be greatly appreciated.
Thank you!
https://imgur.com/a/WgQoyZh
