It is currently Tue Aug 04, 2026 3:20 pm
PostPosted: Wed Sep 10, 2008 9:15 am
All new water wear from Hobie
(Inventory will be available to ship in early October)
Click for Size Chart
Click for larger image
HOBIE SPRAY TOP 99.95
3850SM / 3850MD / 3850LG / 3850XL
The Hobie Spray Top can be worn with swim trunks or over a wetsuit. Mix and match layers to get the comfort you desire. Spray and wind protection. Breathable 5000cm3 nylon shell.
Construction Features:
Neck and wrist seals
Neoprene waist seal
Offset chest pocket
Arm patch pocket
HOBIE RASHGUARD - SHORT SLEEVE 27.95
3851MD / 3851LG / 3851XL
HOBIE RASHGUARD - LONG SLEEVE 34.95
3852MD / 3852LG / 3852XL
Hobie Rashguard for comfort inside your wetsuit and great sun protection when you don't need a wetsuit. This short sleeve design and a high turtle neck style is ideal for any watersport where you need to be more comfortable in your wetsuit, the Lycra material with its 4 way stretch and tight fitting design will let your wetsuit slide on easy when you are getting ready and gives you more freedom when on the water. Raglan sleeve design allows the wetsuit to move so you do not get rubbed and sore - hence the name RASHGUARD - does what it says! The high neck Turtle neck design protects your neck from being rubbed by the suit when in salt water and a sand environment.
UV protection - this top is rated at 50+UPF which gives you the MAXIMUM PROTECTION from harmful UV rays - stopping over 98% of the rays getting to your skin! Ideal for use with board shorts on very hot days in exotic locations - so if you are off to the Caribbean in the winter make sure to pack your Hobie Rash Guard.
Construction - Made from 8oz Spandex Lycra with 4 way stretch and feature overlocked seams which are strong and robust.
RED / BLACK
HOBIE - SHORTY 2/2 RED/BL 129.00
3853SM / 3853MD / 3853LG / 3853XL
SOLID BLACK
HOBIE - SHORTY 2/2 BLACK 129.00
3855SM / 3855MD / 3855LG / 3855XL
Hobie Shorty Wetsuit 2mm/2mm Great comfort for spring-like conditions. Add the Hobie Spray Top to further extend the cool weather comfort range. Add a rash guard for chafe protection. Vertical back zip entry.
Features:
Anti-choke neck
Armortex seat
Lumbar Flex Zone
Construction:
100% Dura Flex with mesh chest and back panels
Glued, Blindstitched seams
RED / BLACK
HOBIE FULL WETSUIT - 3/2 RED/BLK 179.00
3854SM / 3854MD / 3854LG / 3854XL
SOLID BLACK
HOBIE FULL WETSUIT - 3/2 LG BLACK 179.00
3856SM / 3856MD / 3856LG / 3856XL
Hobie Full Wetsuit 3mm/2mm For colder days. Add the Hobie Spray Top to further extend the cold weather comfort range. Add a rash guard for chafe protection. Vertical back zip entry.
Features:
Anti-choke neck
Armortex knees
Lumbar Flex Zone
Construction:
PostPosted: Thu Sep 11, 2008 5:47 pm
Hi Matt,
Will there be larger sizes available in the future?
I wear XL but when I rented a 3XL wet suite from the dive shop it was too small. Couldn't zip it up the back.
How will the sizes run? I guess one needs the chest , waist, height & hip size of the wet suite.
Been looking for a wet suite.
Thanks, Bruce
Everything before 60 is just a rehearsal!
PostPosted: Thu Sep 11, 2008 10:01 pm
mmiller wrote:
This is it for the moment. The links are all working, so perhaps was down for a bit when you looked?
These will be in our fall catalog... I hope to finish later this month.
Works now. Thanks.
Tim
'09 Adventure, Golden Papaya, Turbo Fins, Large Sailing Rudder, Turquoise Sail, Grey Haired Kayaker, ...
PostPosted: Fri Sep 12, 2008 5:28 am
Thanks Roadrunner,
That helped.
Looks like I will need to wait for larger sizes. Chest is too small.
Bruce
PostPosted: Fri Sep 12, 2008 10:17 am
Wetsuits arrived!! Lycra stuff is still due in October.
PostPosted: Wed Jan 14, 2009 11:24 am
We have been getting great feedback on the spray tops and wetsuits - people love the flexibility and mobility provided by the materials we've used. The Hobie wetsuits also feature fully dry seams - so the are super warm!
Now's the time to invest in some gear that will last for years to come. (I am currently using a 3 yr old prototype of the 3/2 full wetsuit, and its still running fine...no leaks or tears and we are in wetties 10 months a year in California since the water never warms up much)
All items are in stock - to order or try one contact your nearest dealer toll free for help 1800hobie49
PostPosted: Sat Jan 17, 2009 8:11 pm
I love the look of the new gear and would probably stock up on all of it but Hobie and other manufacturers does not make stuff that fits larger people. Im not fat but Ive tried xxl rash guards on and they are still skin tight lets hear it for the normal sized people
