It is currently Wed Aug 05, 2026 10:27 am
PostPosted: Thu Jan 21, 2010 3:09 pm
The spine on my steel-sprocketed Mirage Drive cracked at the main axle set screw. I ordered a replacement spine, but the drum shaft from my old drive doesn't seem to fit in the new spine. Do I need a new drum shaft to fit the new spine, or should I just get a bigger hammer? :twisted: :lol: I thought I'd ask here before I tried hammering stainless steel through plastic.
Also, if I need a new drum shaft, will it work with my old drums?
Thanks in advance.
PostPosted: Thu Jan 21, 2010 6:01 pm
Should be the same as your original spine. Bigger hammer I think. The new drum shafts are backwards compatible with spines, drums and hulls.
PostPosted: Fri Jan 22, 2010 7:17 am
Excellent. Thanks, Matt. The bigger hammer route is usually my go-to option, but I'm starting to learn from past mistakes. :lol:
cron
