It is currently Tue Aug 04, 2026 6:39 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 30, 2008 6:25 am
I'm still pretty impressed with this stuff. It's cheap, it's dry, it lasts and it works.
http://www.webbikeworld.com/t2/motorcyc ... n-lube.htm
I rinse my drives with fresh water and give all the lube points a quick shot of this dry lube, though I could probably skip a few times in between.
This stuff would be overkill at $500 a tube... The liquid #8152 is twice as expensive, but one drop will spread itself out so much it's incredible. Once something is lubed it stays lubed. The only way to get it off is to use a special cleaner. Soapy water, ethanol, acetone, MEK, or mineral spirits won't touch it.
http://www.2spi.com/catalog/vac/braycot ... eases.html
http://www.castrol.com/liveassets/bp_in ... sh_pds.pdf
TC
