It is currently Tue Aug 04, 2026 7:46 pm
PostPosted: Mon Aug 31, 2009 6:16 pm
Roadrunner, do you have to cinch your sailing rudder "hard". If I don't cinch all the way, till the cable is very tight, the rudder will lift at higher speeds and I lose right rudder authority. A hard cinch is okay in deep water, but I am concerned that such a hard cinch will cause something to give and break if I hit something underwater.
Absolute kayaking corrupts absolutely.
PostPosted: Mon Aug 31, 2009 9:10 pm
Yes, I cinch it up tight -- that's the way it's designed. I believe the system has some additional "give" built in. Also, the rudder pin is engineered to fail if necessary to save the rest of the assembly. A spare pin costs about $3.50.
Adventure Islands break their pins occasionally due to high sailing speed and high rudder pressures so they come with spare pins as original equipment. I believe all the 2009 (and some 2008) 8" hatches incorporate a slot for pin storage. Here's what it looks like (with spare pin in):
So cinch your rudder down firmly, carry a spare pin, make sure you know how to push the old pin out and drop the new one in on the water (just in case) and your rudder should behave very well. I think it's very unlikely that you'll break a pin, but it's good to be prepared. 8)
PS If you customize the bottom of your rudder, a little radius (about the size of a quarter or so) on the leading edge is good to have.
PostPosted: Mon Aug 31, 2009 10:26 pm
I love that storage place for spare pins. I hadn't even noticed that before.
Thanks for the rudder info. I'll order some pins and breath easier while using this bigger rudder. I love the turning response when peddling. Will sail it asa we get a good windy day.
Thomas
