It is currently Tue Aug 04, 2026 1:07 pm
 Post subject: Revo against the wind
PostPosted: Mon Jul 21, 2008 12:21 am
As my wife never comes out with me I have swapped my Outfitter for a Revo. I took it out yesterday for the first time. Fairly calm but a 12 mph breeze. After finding out that the Revo needs a different entry technique to the Outfitter :) I got on with it very well. It handles much better than the Oufitter does solo. One thing surprised me though. Having ended up some way downwind I was expecting a slow slog upwind. Instead I seemed to get a lift and travelled upwind, seemingly, as fast as downwind. It appeared that my body was acting as a sail and the Mirage drive as a keel. Is this a little publicised advantage of the drive or was I just lucky on the day?
malcolm in the UK
PostPosted: Mon Jul 21, 2008 12:14 pm
Hi malcum. I agree, Hobies are really good against the wind and the Revolution is excellent. I also enjoy a stiff breeze with the Adventure as it slices into the chop and peals through the wind:
8)
PostPosted: Mon Jul 21, 2008 6:05 pm
Hobie Team Member
Interesting concept.
Did you try tacking about 20-30 degres off a direct into wind course to test your theory. You might go even faster.
PostPosted: Mon Jul 21, 2008 8:20 pm
Hi Ya'll
Ok so just exactly what type of features on a sailing kayak makes one kayak better going upwind than another kayak ?
Is it rudder shape , hull shape, sail size, sail shape, two sails or all of these and something more ?
Just curious what the general consensus might be on that . :?
Kepnutz
PostPosted: Mon Jul 21, 2008 11:32 pm
I was about 20-30 deg off a direct into wind course but did not try tacking. I only had to peddle quite lightly but did have to peddle i.e. it did not happen if I was just sitting still. I was using standard fins and rudder. Although only 5'6" I am quite large in the body (too large at 240lbs) and short in the leg. It was a definite lift, as I have experienced whilst sailing when everything comes together and the boat suddenly accelerates and starts to "fly." As soon as I can get back out on the water I will try and experiment some more
Malcolm
malcolm in the UK
PostPosted: Mon Aug 25, 2008 6:18 pm
I nearly always have the sensation that I'm going mush faster when travelling into the wind too. In fact I try to avoid "with wind" headings when I can since it feels so slow (and warm!). I can't believe I'm ACTUALLY going faster when heading into wind ...but it sure it just FEELS like I am going faster. And it's a very strong feeling.
thomas
Absolute kayaking corrupts absolutely.
PostPosted: Tue Aug 26, 2008 1:12 am
Good to find someone else has had the same experience. I have been trying to get back out on the water with a speedometer to check actual speeds but have not had the right weather the few times I have been able to get out. Checking the speed by watching the scenery go past though, the speed increase was real. There were no current effects at the time.
malcolm in the UK
