It is currently Tue Aug 04, 2026 2:15 pm
 Post subject: using loctite
PostPosted: Mon Sep 22, 2008 12:50 am
Is using loctite on the mirage drive mast set screws recommended? Has anyone had to back out a set screw after using loctite?
PostPosted: Mon Sep 22, 2008 3:19 am
Hobie Team Member
The blue 242 works good and the screw is still removeable when necessary.
Roger
http://www.aldenofsunapee.com/
Image http://www.NEKF.com/
PostPosted: Mon Sep 22, 2008 2:15 pm
Thanks for the help, anything that prevents a mast from slipping out on the water is a blessing.
PostPosted: Mon Sep 22, 2008 2:45 pm
Hobie Team Member
I used a drop on every set screw on the drive.
Roger
PostPosted: Mon Sep 22, 2008 8:49 pm
In my years of using Loctite and I have used a bunch(in years past 2 large bottles of red 271 per year)in some cases Loctite can be very damaging to some plastics it is a truly gr8 product and does not appear to damage the Mirage drive material.
What I use is the paste not the liquid 242 its sold as a stick in a dispenser similar to a chapstick tube the benefit of this is getting the Loctite were you want it not running off everywhere else item#37643 I just put it on the threads of the bolts before install this a big improvement over the liquid.
Fastfish/Geoff
Kayaks Owned>Outback/Mine & Revolution/Wife
PostPosted: Tue Sep 23, 2008 3:59 am
Hobie Team Member
Thanks for the heads up fastfish. I will look for the paste.
Roger
