It is currently Tue Aug 04, 2026 5:31 pm
PostPosted: Sun Feb 01, 2009 2:54 pm
I need to replace my left pedal axle and pedal. If I order the crank assembly (part no. 81221001), do I get the crank, adjustment pin mechanism AND THE PEDAL?
Thanks, /bing
PostPosted: Sun Feb 01, 2009 5:04 pm
That p/n does include the pedal (according to the parts catalog). But I don't believe it includes the pedal adjustment assy.
PostPosted: Sun Feb 01, 2009 7:08 pm
It's easy to transfer the old one over. As I remember, it should go on before you install the pedal assembly. 8)
PostPosted: Sun Feb 01, 2009 8:26 pm
Thanks. I ordered the assembly.
Both axle and pedal are toast. Axle has a wobble, and the wobble wore out the pedal. Need to replace both. Just needed to see if I had to order a seperate pedal after ordering the crank assembly. Glad to see its only a 40 buck fix.
/bing
