It is currently Tue Aug 04, 2026 5:18 pm
PostPosted: Mon Mar 09, 2009 4:22 am
I was replacing the transducer in the my Revo and I noticed that mast receiver tube has about 1/8" play at the bottom. I don't recall any play in the tube when I originally installed the transducer.
I did mange to turtle my Revo twice :roll: when sailing this summer so I am wondering if I have managed to damage the tube then. There is no obvious sign of damage.
Is this normal or should I replace the tube.
Cheers
Grant
PostPosted: Mon Mar 09, 2009 9:33 am
You can remove the the fitting to inspect. Use a VERY long and large slot screw driver from the top and down inside to the base and un-thread the part from the hull. Inspect and re-insert.
PostPosted: Tue Mar 10, 2009 2:56 am
Cheers Matt. I removed the tube and there was no sign of damage.
When I screwed it back down I noticed it didn't go all the way down to the hull. I will place some silicone under the tube which should do the trick.
Regards
Grant
PostPosted: Tue Mar 10, 2009 10:10 am
Just be sure it is seated over the nub in the hull.
