It is currently Tue Aug 04, 2026 4:21 pm
PostPosted: Thu Mar 12, 2009 11:59 am
I want to replace the lousy wheeleez brand wheels and tires with new wheels that have airless tires. I got two flats yesterday going across sand dunes.
Maybe I can put airless tires on the wheels I have now? Any ideas?
PostPosted: Thu Mar 12, 2009 12:53 pm
Pneumatic wheelbarrow wheels are better for where I live. It was suggested to me that if I got the big wheeled cart that I fill the tires with foam (I'm in rocky hill country with lots of cactus) I don't have sand here.
PostPosted: Thu Mar 12, 2009 12:55 pm
When you say foam, are you talking about that construction foam that is used to fill in holes and openings?
PostPosted: Thu Mar 12, 2009 12:58 pm
I didn't get the big wheels, and I haven't tried foam, seemed to me the wrong kind of foam could overexpand, causing a rupture.... Regular foam like that that hardens, I had blow out a wall once when I filled a wall with it.... blew the sheetrock off the studs .... A newer type "door and window foam" is supposed to "not overexpand" in a wall .... but it might in a soft wheel. And, I don't know a low about foams.
That's just what someone suggested when I thought about buying the wheeleez tires, not sure what foam they meant though.
PostPosted: Thu Mar 12, 2009 5:03 pm
Seeing your other posts and the loads likely carried by your cart... wow! The cart would be at max capacity carrying all the stuff shown in the other post, a 70-80 lb tandem, 60 lb car battery, 30 lb motor, crate and any thing else that may have been in the boat. Low pressure in the tires may also cause a pinch the tube or valve stem. I would also be careful about the scuppers themselves using a plug in cart. They are not designed to carry the boat with a full load of accessories too. There are other dolly products out there that are designed to better support a heavy hull over distance. We are currently in the final stages of development of a sling cart for the Pro Angler. This one would be a good choice for any of the kayaks. Especially when loaded with gear.
