It is currently Tue Aug 04, 2026 6:33 pm
 Post subject: cleaning gunk off kayak
PostPosted: Sun Sep 06, 2009 7:30 am
What is recommended for cleaning my kayak. I use it regularly in ocean and rinse it with water afterwards, but there is a fair amount of gunk, for lack of a better word, on it. I have tried liquid soap but not very effective. Any ideas? I love my new turbo st's. Also my friend and I saw a crocodile in water off Coconut Grove, Fl. recently. Assumed it was a crocodile because of salt water..I did some fast peddling..
PostPosted: Sun Sep 06, 2009 10:10 pm
409 worked in with a tooth brush does pretty well on oily residue. Hobie also sells a boat cleaner that works well. They are formulated differently but seem to be about equally effective in removing my local crud. Here's a before and after in the Drivewell area:
As you can see, my boat is white so deposits show up easily. The Hobie brand is probably more environmentally friendly. For the toughest stuff (rubber skid marks etc) or a good deep cleaning, I use a cleaner-wax (like Maguire's) -- but only on the smooth (bottom) surfaces.
When the hull is clean, I like an occasional application with Hobie Protectant. It puts a nice shine on the boat and holds up a little better than 303 on a side-by-side test. Here's what it looks like on my 3 year old Adventure:
I spray it on and chase it with a damp rag right away -- quick and easy to use. It's quite slippery so watch where you use it. 8)
PostPosted: Mon Sep 07, 2009 4:25 am
Thank you for the advise on cleaning kayak. I have the hobie portectant and will use after cleaning. Can't believe the shine on yours. good to know..
PostPosted: Mon Sep 07, 2009 6:09 am
I have a 09 Revo & a 07 Sport. I find that a power washer works best for me. It doesn't seem to hurt the hull. A little Simple Green helps with grim that has oil in it.
Bruce
Everything before 60 is just a rehearsal!
