It is currently Mon Aug 03, 2026 9:30 pm
 Post subject: my butt gets wet
PostPosted: Tue Apr 26, 2005 10:45 am
my butt gets wet in my outback. i'm only 170 lbs, but water comes up through the hole under the seat and eventually gets the seat wet.
anybody got a fix for this one?
thanks all.
PostPosted: Tue Apr 26, 2005 4:06 pm
The Outback comes with a small scupper plug that goes in that drain hole beneath the seat. With the plug installed you'll stay dry. If you didn't get one with the boat call your dealer. In the mean time you could plug the small hole with whatever fits. Looks to be about the same diameter as a hot dog. :P
 Post subject: Re: my butt gets wet
PostPosted: Tue Apr 26, 2005 8:33 pm
nirvan wrote:
i'm only 170 lbs, but water comes up through the hole under the seat and eventually gets the seat wet. anybody got a fix for this one?
If playing in waves, my whole body gets wet. On the smoother rivers, my butt never gets wet. Didn't even realize there was a hole under the seat until seeing your post. Had to go out with a flashlight to see and sure enough, there is a hole. Sitting on a closed cell foam pad is probably keeping my butt dry.
