It is currently Tue Aug 04, 2026 6:33 pm
 Post subject: Safety flag & Lightning
PostPosted: Fri Dec 04, 2009 8:20 pm
Hi I'm new and this is my second post.
Does mounting a safety pole/flag increases the chances of a lightning strike? As I know, lightnings like pointed objects. The one I have is fibreglass and 70plus inches(http://www.cabelas.com/cabelas/en/templ ... d=cat20161)
Will running a metal from tip into water helps or does nothing at all?
Hobie also has a nice one at 4feet but I find it a little short.
More pics/vids in My Fishing/Kayaking Blog
Image Image
PostPosted: Sun Dec 06, 2009 9:53 pm
IMHO the best thing is to not be on the water during a lightning storm. :shock:
PostPosted: Mon Dec 07, 2009 11:10 am
But the rule is yes, the more height the more chance BUT, at least it may hit IT instead of your head poking up there (if its a better ground than you and the water). Either way it's moot as atavuss says, you shouldn't be there.
PostPosted: Mon Dec 07, 2009 3:50 pm
I'm in the tropics. Lightnings strike even in clear weather! You can go out sunny nice but come back soaked wet chicken :)
I read the cabling need to be significantly thick/wide if not it will melt or something?
And copper or aluminium?
Image Image
PostPosted: Mon Dec 07, 2009 5:03 pm
I'd go copper and the length of your craft maybe even a very wide strip, you need area to dissipate the charge. I can't believe I'm even saying this! Hard to imaging surviving a hit that close to you :shock: My friends Whaler got hit last summer moored with no one on it. You could tell by the burn marks that if anyone was holding onto metal they would have been charred, but the energy came out the outboard with no real harm done to the rest of the boat.
PostPosted: Mon Dec 07, 2009 10:46 pm
I will be (at least my current intention) running the cable from tip into water, cable-tieing it along the fibreglass whip. That whip is >70inches so alum is better as it's lighter. Copper being heavier would most likely sag it down.
And copper corrodes faster right?
Image Image
PostPosted: Tue Dec 08, 2009 6:33 am
Good point. I think it does.
PostPosted: Tue Dec 08, 2009 7:22 pm
I'm no kind of expert but here are some thoughts:
    The chances of a 70" fiberglass rod attracting a lightening strike are negligible IMHO
    The chances of a 70" conductor attracting a strike are slightly higher
    If lightening does strike, a light conductor would likely blow like a fuse and leave the lightening looking for an alternate path, you?
    Alumium is a great conductor and lightweight but also melts very easily
    A lightening strike is likely to leave you with a major hull leak, think flotation and repairs
    Even a nearby strike will probably leave your onboard electronics inop so think self sufficient, low tech
    The cheapest, simplest, and probably safest solution is to simply pull the pole out and secure it with your paddle bungee and stay low until the threat passes
PostPosted: Sun Jan 10, 2010 7:53 pm
I live in the lightning capital of the world. I don't go out if there is threatening weather. If I am out when a storm comes up, I hunker down and seek shelter. First thing I do is get the fishing poles down and make myself as small as possible.
So to answer your question... I wouldn't use a flag pole on my kayak unless I was in extremely heavy boat traffic area...then I wouldn't be there.
I wear flagman flourescent green with the reflector tape on it. Walmart, $4.97. Bright and great for night fishing. NO SAFETY FLAG for me
Hard Core Kayak Anglers Club
