It is currently Mon Aug 03, 2026 11:48 pm
PostPosted: Mon Jun 13, 2005 2:43 pm
My rudder line broke inside the hull. I pull from both ends and am unable to pull the line out. Does anyone have a video or description on how to totally replace a broken rudder line? I think the stearing lines are ok, but just need some adjustment as have stretched out.
RLear
PostPosted: Mon Jun 13, 2005 8:54 pm
It depends on what broke and where. If you are not sure what broke and where to connect it, I recommend you take it back to your Hobie dealer and let them fix it, especially if it is still under warrantee.
PostPosted: Thu Jul 21, 2005 6:48 pm
what kind of line is it? mine is only 4 days old and it is frayed :shock:
78 VW Riviera
 Post subject: Frayed
PostPosted: Thu Jul 21, 2005 8:17 pm
We have been having some burrs on the little loop of stainless at the bottom of the rudder mount fitting. The line passes over this and could get frayed. A little attention there can prevent the problem. Something the factory has already been doing.
