It is currently Wed Aug 05, 2026 2:18 am
PostPosted: Sun Mar 21, 2010 9:45 am
any suggestion/recommendation/advice?
big crack in one of the holes where the wheels' poles go.
PostPosted: Mon Mar 22, 2010 2:18 pm
Ouch!! That really sucks!! :cry:
PostPosted: Mon Mar 22, 2010 3:09 pm
Contact your dealer. Supply them with photos if you can't get to the dealership. Cracks like this can be caused by improper cart use, but also from thin material coverage.
PostPosted: Mon Mar 22, 2010 6:47 pm
If it's not covered by warranty, you should be able to sleeve it from the inside of the boat (through a hatch opening) using 3M Scotchweld DP 8010 or Loctite 3030 -- both very strong and excellent bonders with Polyethylene. If all else fails you can plug it, seal it and go to a different style of cart. 8)
PostPosted: Wed Mar 24, 2010 8:59 am
I have not seen this product before but it looks very promising for us. TARTAN23455 in another thread stated once it is applied properly it will not come off.
What you could do is get some 4" wide EternaBond tape and use it to cover the holes and cracks etc. I used it on my motor-home and if put on properly it WILL NOT come off. No matter what!
Check it out!!
http://www.eternabond.com/articles.asp?id=166
http://s909.photobucket.com/albums/ac294/gsammy925/
