It is currently Tue Aug 04, 2026 8:49 pm
 Post subject: Plastic adheseive
PostPosted: Thu Apr 08, 2010 3:57 am
What type of plastic is the Revolution made of? Will Polyurethane construction adhesive hold on it?
In order to eliminate "skeg rash" I made a stainless steel cover for the skeg.
I could attach it with bolts but I'd rather not drill in the bottom below the waterline, if I don't have to.
 Post subject: Re: Plastic adheseive
PostPosted: Thu Apr 08, 2010 9:17 am
The kayaks are molded from Polyethylene. There has been discussion in these forums about adhesives. I believe roadrunner discovered that a 3M Scotch Weld DP 8010 was quite good.
PostPosted: Thu Apr 08, 2010 9:44 am
If I used bolts, would it void the warranty?
PostPosted: Thu Apr 08, 2010 9:54 am
If the boat were to crack due to drilling and using bolts? That would not be covered by warranty. Would not effect any other issue that might come up.
