It is currently Tue Aug 04, 2026 8:57 pm
PostPosted: Sun May 16, 2010 10:12 am
The shafts that connect the pedals to the actual drive can be adjusted for different length kayakers. This is done by pulling a pin that fixes the position of the arm to one of several holes on the drive.
My older Mirage has a spring loaded pin set in a u-shaped clip that holds the pedal shaft securely to the drive. I've lost a couple of these clips, so the pedal without the clip doesn't help with any of the work. I am looking for replacement pins.
The current parts catalogue shows a pedal adjustment assembly that looks different from what I have. Does anyone know if this new assembly with work on older models and similarly does anyone know if the older clips are still available and where to get them?
PostPosted: Sun May 16, 2010 5:29 pm
The current system will work on an older drive. The original spring clips are no longer available. You can also use a simple bolt and nut if not doing a lot of adjusting. Some prefer that way as it makes a tighter connection.
PostPosted: Mon May 24, 2010 1:01 pm
Thanks, MM. I've used a shackle pin, but it fell out and it's nice to know that the new clips they sell will work ok with my old drives.
PostPosted: Mon May 24, 2010 10:37 pm
It makes a great improvement! Here's a 2000 Drive with its original pin arrangement:
Here's the same Drive with the current "pedal adjustment" upgrade (note, "Drive Seal", far right, has also been added):
You can also add a pair of pedal adjustment decals for a dollar.
Much easier to use!! 8)
PostPosted: Tue May 25, 2010 4:30 am
Thanks, roadrunner. The pix are great.
