It is currently Wed Aug 05, 2026 5:27 am
PostPosted: Sun Jun 06, 2010 5:34 pm
I just recieved a lanyard for my mirage drive and want to install. My drive is from 08 and doesn't have the triangle cut out like the one in the FAQ section above.
Can I just drill a 1/4" hole and use a clevis ? Or is drilling something I shouldn't do?
I bought the splash guard too and want to screw it on. Any suggestions on what SS screws to use?
Thanks in advance for the help.
PostPosted: Mon Jun 07, 2010 11:45 am
You can drill.
The accessory splash guard uses zip ties... sure you know. If you want to do the factory install: We use tapped holes. 2 each #8 x 5/8 screw. #10 washer.
PostPosted: Mon Jun 07, 2010 3:11 pm
Thanks Matt. I'll probably drill and tap. Thanks for the info on the drive leash too.
