It is currently Wed Aug 05, 2026 8:21 am
PostPosted: Tue Jun 29, 2010 9:37 am
I've had some difficulties with the Twist-n-Stow rudder on my Revo. One of the issues was during a back troll while halibut fishing. One of the rudder control cables "jumped the track" and became inoperable.
Back at home investigation through the rear hatch revealed that a pad-eye attached by one end to a hatch screw was the method the assemblers used to guide the rudder control cables. When the cable jumped out of the half-attached pad-eye, the slack introduced rendered the rudder in-op. I don't know whether this is the standard Hobie rudder cable guide, but I suggest replacing these things as shown below.
Here is a photo of the pad-eye from the inside, and a photo of my replacement solution.
PostPosted: Wed Jun 30, 2010 6:17 am
I have a revo too. I had the dealer upgrade mine to the up/down levers. It looks like your setup. I zip tie the cables just enough to prevent them from becoming loose.
John
PostPosted: Thu Jul 01, 2010 2:11 am
Nice idea. If mine acts up I'll try that route. thanks
PostPosted: Fri Jul 02, 2010 8:19 am
The plastic pipe clamps are much cheaper than the pad-eyes. You have to wonder what Hobie was thinking. I am still not sure a half-attached pad-eye is part of the standard design.
