It is currently Wed Aug 05, 2026 3:11 am
 Post subject: Dry Deck
PostPosted: Wed Jan 19, 2011 10:05 pm
I always love fishing on my outback. Problem is that my shoes is always getting wet and always touching the water around the mirage well. Finally, I decided to do this project called "dry deck". Now, my shoes will always stay dry and will not be touching the water. Check it out!
http://pogieeh.smugmug.com/Boats/dry-deck/hobie-dry-deck/1163076038_bL4Tc-L.jpg
 Post subject: Re: Dry Deck
PostPosted: Fri Jan 21, 2011 6:46 am
Looks like a nice fix for your problem. Is it strong enough to stand on?
For me I have a lots of uses for a little sloshing water around the drive well.
Splashing water on the head, feet, and butt help wash off the fish guts and keep the blood from hardening on my shirt and pants. On one occasion I had several shrimp come up through the well. Getting dirty and wet is in the Dictionary as the definition of Kayak Fishing.
I'm right 98% of the time. The other 3% I don't worry about.
PostPosted: Fri Jan 21, 2011 6:17 pm
Any more pics, whats it made from?
PostPosted: Fri Jan 21, 2011 7:13 pm
It's made from rubber mat and plywood. Here's more pics.
PostPosted: Fri Jan 21, 2011 7:59 pm
It's all about preference. I prefer not to get wet since I only do freshwater fishing at the moment but I'm sure that I will be saltwater fishing in the future. In reference to the material, it's made of plywood and rubber mat. The only challenge would be the measuring of the hull. After that, it's all elementary.
PostPosted: Sat Jan 22, 2011 8:43 am
Thanks for that info. I like to stay dry myself, you would of loved the Pro angler if you like staying dry, but i like my outback also.
PostPosted: Wed Jan 26, 2011 1:07 pm
Hobie should have a trade program so people can upgrade to newer products.
PostPosted: Thu Jan 27, 2011 6:14 pm
Like St.Croixs rod trade up program.
PostPosted: Fri Jan 28, 2011 7:27 am
I like the concept for the winter months. The metal latches are a short term use. How often do you think you will need to replace them? thanks
PostPosted: Fri Jan 28, 2011 7:33 pm
I've used it a couple of times and it keeps me dry. I also lube the latch after use and so far so good. Luckily, latches are only 2.69 for a pair at home depot.
PostPosted: Tue Feb 01, 2011 6:23 pm
How thick was the plywood and the mat material? It looks like a neat idea to me.
Mike
2015 Pro Angler 12
Yellow with Humminbird side imaging
