It is currently Wed Aug 05, 2026 12:17 pm
 Post subject: Leak fix?
PostPosted: Mon Apr 18, 2011 7:39 pm
Just made my first trip out on my outback. Came back in to find a good amount of water below deck. I found the leak coming from the white plug in front of the mirage drive well. Is this a common spot for leaks and what is the best way to fix the leak?
 Post subject: Re: Leak fix?
PostPosted: Mon Apr 18, 2011 9:17 pm
Take it to your dealer. Sounds like a Mirage well crack. Not normally repairable.
PostPosted: Tue Apr 19, 2011 6:22 am
Ok will do. I bought the kayak in South Carolina. I hope a NJ dealer will help me out. What is the purpose of the white plug near the well? I was thinking of putting some marine goop around the area inside the hull first.
PostPosted: Tue Apr 19, 2011 9:40 am
Behind the white plug is a brass fitting, just used to attract more plastic to that area during manufacturing. That area was a problem with cracks in the first year of production for some AI's (both of mine were replace), so needed more plastic. The white plug just covers it and makes the bottom smoother. there should be no through-the-hull openings in the boat below the water line, except the drain plug on the newer models.
PostPosted: Tue Apr 19, 2011 10:56 am
Thanks for the response I will take it to a local dealer and get it resolved.
PostPosted: Tue Apr 19, 2011 7:03 pm
Try John in Brigantine Nj...He's the man...
SpinfisherBob
Barrell Surf and Kayak
609-266-2505
Hobie Fishing Team Rider
Stay Fit, Go Fish, and Have Fun
SpinfisherBob
http://www.youtube.com/user/SpinfisherBob
PostPosted: Wed Apr 20, 2011 3:10 pm
Is this a new or used boat?
