It is currently Wed Aug 05, 2026 4:13 pm
PostPosted: Thu Sep 29, 2011 3:44 pm
I installed the turbo fins and with just pushing them back and forth out of the water it seems like the mirage drive is stickier. I dont know if i somehow managed to get loc-tite in the mirage drive or if this just happens because of the added weight. Any ideas?
PostPosted: Thu Sep 29, 2011 4:25 pm
Should not make the drive stickier, but the added weight / mass of the Turbos and the longer masts might make is seem a little heavier to pedal, but not much I'd think. The big difference is when in the water.
Maybe the clew adjustments are really tight? back them off to about mid point.
PostPosted: Fri Sep 30, 2011 8:13 am
This is good for power, but back on the clew screw if you think you want less sticker... But I would try in the water before adjusting... Good luck
PostPosted: Fri Oct 21, 2011 7:48 am
The turbo fins will add a little more resistance while pedalling, but you get used to it pretty quickly. you only need one pedal per every 2-3 with reg fins.
Matt Baden
http://www.thehobielife.blogspot.com
AFTCO, Kanan Lures, Astral Buoyancy and Alltackle.com Pro Staff
2012 Yellow Pro Angler 12 and 2014 Pro Angler 12
