It is currently Sat Aug 01, 2026 6:53 pm
PostPosted: Mon Oct 03, 2011 4:23 am
Hi guys,
Just wondering if there's a knack to removing the Mirage drive click-n-go mounts from the hull?
I can see the rear-most Allen screw, but the front one seems to be masked the the cam activation mechanism.
Do I need to remove this to gain access to the front Allen screw?
Cheers,
Mike.
PostPosted: Mon Oct 03, 2011 11:48 am
I just use a long shaft 3/16 Allenhead. It slides in at an angle along side the toggle at the front housing recess. If you remove the rear screw first, the unit will move around for better positioning after you get it started.
Don't forget the Loctite on re-installation. 8)
PostPosted: Mon Oct 03, 2011 2:57 pm
Use a ball-end allen for best results. Allows a sharper angle of attack.
PostPosted: Tue Oct 04, 2011 2:49 pm
Thanks for the reply guys...
I found a suitable allen key, but no matter how hard I tried the rear screw wouldn't budge.
In the end I gave up, as it felt like something was going to break!
Cheers,
Mike.
PostPosted: Tue Oct 04, 2011 4:49 pm
LocTite can be hard to break, but it should come loose.
PostPosted: Sun Jul 12, 2020 3:48 pm
I replaced the right click and go today, it was worn and unstable, causing the spring to break i believe. I was able to remove it , although the screw towards the front is a little difficult to access . On the re-install i removed the 2 small screws that keep the plastic "housing " together on the click and go , and that allowed easy access to the screw .
PostPosted: Wed Mar 24, 2021 9:28 pm
When I replace the click n go I should use locTite on the threads? What grade? Thanks!
PostPosted: Thu Mar 25, 2021 1:10 pm
Don't use Red but Blue so you can take apart if needed in the future.
Dr.SteelheadCatcher
Warrenton, OR
