It is currently Wed Aug 05, 2026 6:21 am
PostPosted: Mon Nov 07, 2011 7:47 am
Hi , does anyone have any experience in replacing the control line on a Mirage Classic? I am alos looking for the owners manual for the Classic. My instructions say 7) See the owners manual for line adjustment information. The dealer also had picture instructions for attachment inside the body. He stated that it would be included with the Universal Control line kit #80020001, but all i recieved was a 7 itme list of instructions.
Bob
PostPosted: Mon Nov 07, 2011 10:02 am
On the support pages:
http://www.hobiecat.com/support/products/kayaks/
Original Rudder - Lever Up-Down
Hobie Mirage rudder line replacement PDF (114 KB)
http://2010.archive.hobiecat.com/support/pdfs/80018.pdf
Video Tech Help for Original Rudders
(Windows Media Player Required)
May require a Microsoft Media Player Upgrade.
For Best Results, Save the Videos to your PC:
1. Click the link with the Right mouse button.
2. Choose "Save target As..." and select a location
(High speed connections can play video directly from our server)
Original Hobie Mirage Rudder Installation Video
(1 min 50 sec / 10 MB)
Original Hobie Mirage Steering Adjustments Video
(2 min 40 sec / 15 MB)
http://2010.archive.hobiecat.com/support/video/kayak/SteeringAdjustment.wmv
PostPosted: Wed Nov 09, 2011 11:37 am
Matt,
Thanks for the guide and video.
2 more questions:
1. since i have the (old) metal inserts for the control line tubing am i correct that i will need to bore a larger hole in the kayak to accomadate the new plastic insert?
2. does the large hatch cover on the mirage classic need any sort of gaskets in order to keep the water out, or are the bungees sufficient?
Bob
PostPosted: Wed Nov 09, 2011 3:56 pm
The Classic's large hatch had a gasket on it. Same stuff we use for the current cargo type hatches. You need 71301001 (6.5') (Trim Loc) I pushes onto and clamps to the black plastic hatch lip / edge.
I believe you can use the line replacement kit #80020001 or just run spectra through the existing holes.
