It is currently Sat Jun 20, 2026 5:23 pm
PostPosted: Tue Nov 29, 2011 7:11 pm
Does the T handle upgrade kit work on the 2006 Adventure?
PostPosted: Wed Nov 30, 2011 12:52 am
If by "T-handle kit" you mean the kit to change from the rudder raise/lower lever to pull cables to raise & lower the rudder then, yes I believe it does.
I installed the kit in Adventure of mine which had the raise/lower lever system and was about that vintage.
It wasn't too hard to install (the instructions that came with the kit were pretty good) and was a worthwhile upgrade as the rudder raise/lower lever required quite a bit of grunt whereas by comparison the pull cables are a cinch.
